Problems binding Tekin RS Pro w. M11x...
I swear I have tried everything and can not get the ESC to bind to the Airtronics M11x? I had this issue with my Spektrum turned out to be the throttle expo was to low in the settings, dialed it up and it worked. I tried that with the M11x and still nothing.
Anyone have any suggestions to try? Thanks! :nod: |
Originally Posted by SaladFork
(Post 7414351)
Originally Posted by mjc168
(Post 7415350)
did you set your throttle to normal mode? 4pk required reverse mode and m11x required normal mode, please check.
Thanks for your help! |
sometimes these newer esc's don't like it when the epa (end points) are not set even ie: 160 high/140 low. Try setting them both even.
| All times are GMT -7. It is currently 09:40 AM. |
