New Products from Radiopost Korea!!
#616
hi,
has anybody already tried to use the radio with the VRC-3 adapter (virtual rc racing)? Does it work with it or do I have to buy the VRC-3NT adpater?
#618
I believe you need the VRC-2. The VRC-3 did not work for me so i went with the older VRC-2 (Seperate lines for the steering and throttle plug) THe VRC-3 had the white wire feeding to the second plug and that one did not work for some odd reason.
I dont know what the "NT" in VRC-3NT is supposed to stand for. Maybe BKSPEEDO can clarify
Eric Kim
Eric Kim
#619
I also have tested the VRC-3 and it doesn´t work, I also have tried other settings but it doesn´t work.
Maybe I get a VRC-3NT for a test.
#622
vrc-3 works also with futaba T3PM 2,4GHz Fasst. you have to change the settings of the radio, then it will work.
#624
any updates on the new stuff? Aluminum steering wheels! yay... i have an integy one fitted right now but had to modify a Futaba adapter to get it to fit right...
As far as the designs go besides smaller and larger diameter please consider depth/thickness as well as the stock wheel is pretty wide.....
#625
Hey Alvin,
Yes we are working on several different size steering wheel options. I will keep the depth of the wheel in mind.
THanks,
Eric Kim
THanks,
Eric Kim
#626
still cant get over the speed of this radio!
#629
Just want to thank Eric and Radiopost for giving me the opportunity to run the product. Coming from a M11x the TS401 is very easy to use and navigate thru the menu without instructions. Its very responsive to your every input and you feel in tune with the car. Love the small 5 channel receiver, color LCD, adjustable frame rate speed, built in antenna and very easy to bind from radio to receiver. On par with all the high end radio out there on the market for sure. Customer service is top notch and knowing that Radiopost is in my backyard is even better! Can't wait to try out the servo and other future products Radiopost comes out with!! Very happy customer and driver!
#630
i love the look and feel of the radio,do u? has anybody had any problems with running savox servos and lrp sxx or tekin? or unbinding? or any issues? i will be doing a product review on are live radio show here in las vegas on the sep13th at 7pm its called, rc race chat. klav am1230. thanks!!
