Another steering servo question
My Cen Racing Matrix R2 RTR came with questionable servos. The steering servo has a lot of bounce and doesn't center well. I'm just a backyard basher and it's no big deal... I'll upgrade the servo at some point. I've read through the "what servo?" threads here and will eventually buy a good one when I have the extra cash to burn.
In the mean time, I do have a new HiTec digital HS-5645MG in the workshop (I've been flying R/C for years and the Matrix R2 is my first car). With the 6V receiver pack I have in the Matrix, the HS-5645 will put out 164 oz/in of torque and move 60 deg. in .18 seconds. I also have an HS-5625 that would be little quicker (.14 seconds) but somewhat weaker (130 oz/in). Will it be a worthwhile improvement to install one of these servos I have on hand, or would they just get quickly destroyed? (If that's the case, I'd rather save them for airplane use.) Thanks for any advice, desmobob |
The 5645 should be worthy of the job. digital and pretty tough. I race and have used the 5645 as a back up with no issues. I do prefer higher torque than the 5645 can dish out though especially for long term abuse. hope this helps.
The 5645 would be an improvement in that it would center better. I don't know what the specs are on the stock strg servo, the ads I've read lists them as hi torque, metal geared servos. If the 5645 is stronger, I would replace it, if its less torque, then I wouldn't.
Originally Posted by Duster_360
(Post 7375903)
The advertised specs of the OEM Skyion servos are 144 oz/in and .22 seconds transit time at what I would assume is 6V. I'm a little skeptical about the torque figure as I'm able to manually move the servo arm fairly easily with the 6V system turned on. Looks like the HS-5645MG would be an improvement. I'll mount one up tomorrow and give it a whirl (it's supposed to be too cold and windy for R/C flying, so I'll do some R/C driving!). Thanks for the advice guys, desmobob |
| All times are GMT -7. It is currently 03:19 AM. |
