FLYSKY GT3b Transmitter
#1291
firmware ready to go that I built using PSX's firmware generator and QuangVuong's tutorial
It looks like we can flash the firmware now (yay!) to fix the trim adjustment limitation. Awesome. I read through that tutorial, but it doesn't cover extracting the original firmware. Is there another tutorial somewhere for that?
Also, I wonder if it is possible to modify the FW to allow for more than 10 presets? I'm sure this chip doesn't have much storage space, but each preset can't possibly take up more than a couple KB.
#1292
It's a standard 8x12x3.5mm bearing there are alot of companies that make em i just went with the traxxas blue seal ones.
#1293
Does anyone know if this receiver will work on my spektrum.http://www.hobbypartz.com/fs-gtr3c-receiver.html or if Hobby King makes any as well. I'm run a SR3000 receiver and want know if there are any less expensive receivers i can run and if they are worth it too.
#1294
#1295
With your radio hooked up and communicating through the programmer board, go to the ST Visual Programmer menu and select READ -> ALL TABS. That should load your original firmware. Then select FILE -> SAVE AS to save it.
#1296
Hi guy's here is my How to for putting a ball bearing in the GTB3 steering.
Enjoy.
(photos are in order with steps first photo to left #1 and so on)
Parts needed 8mmX12MMx3.5MM normal bearing I used traxxas 2 for $4.00 (see Photo)
1) use a reamer and make the whole larger so the bearing fits in the cover snug with no slop go slowly with the reamer( go from front and rear see photo after hole was inlarged.)
2) Next Push bearing all the way on the steering shaft it fits snug.
3) assemble the parts back together now you have a beauty!!
Enjoy.
#1298
#1299
I have my Merv and slash hooked up on this Radio. When I have both rc's turned on, they both respond to it, it does not matter if my model selected on the radio is on Erevo or slash. Is this normal? or I am missing something here.
#1300
thats normal the model memory only remembers things like endpoints, trims and such...
#1301
Getting Ready to Flash --Software Question
Guys,
I'm getting ready to upgrade the FW on my GT3B and am plannning on trying the "3 wire" connection that fixitrod and others have used.
So here's my rather dumb question:
Do I need to utilize the software tools set or can this basically be accomplished with the web site developed by PXS or these tool used in concert with one another?
TIA for your thoughts.
:harry
#1302
Guys,
:harry
#1303
#1304
Any close up pics or details on the "3 wire" setup?
#1305
We got the radios this weekend and the programming board on Friday. I have done 2 radios in less time than it took me to unsolder the little jumpers on the developer board!
If anyone needs their radio reflashed, let me know via PM.
