FLYSKY GT3b Transmitter >
Like Tree1Likes
Old 06-14-2011, 02:51 PM
  #1726
revoracer10's Avatar
looks kool if it works ill have to get one
revoracer10 is offline
Old 06-14-2011, 04:05 PM
  #1727
Originally Posted by fixitrod
When binding always makesure ABS is off on the tx.
Ok thanks I will give this a shot
Originally Posted by Glenwyatt
Have you tried binding it with any other set-up??
No I have not, I recently had the castle set up with traxxas 2.4 though. Should I try binding with another system?
merx9 is offline
Old 06-14-2011, 04:58 PM
  #1728
kamlooper's Avatar
Originally Posted by byron westman
is there anyone in b.c that can do the mods from page 100 for me. i live in the lower fraser valley
I just ordered a stm8 board. Will let you know if I can help you out.
kamlooper is offline
Old 06-14-2011, 05:17 PM
  #1729
If you're coming down to the coast anytime soon could you do the upgrade for both of us. I would compensate you...
Glenwyatt is offline
Old 06-14-2011, 08:34 PM
  #1730
Where do you get the four pin matrix board and servo connectors at that QuangVuong talks about in his how to reprogram thread? Thanks
cody161 is offline
Old 06-14-2011, 09:01 PM
  #1731
Get a servo cable with connector from hobbie shop. Solder the cut end to the tx board and run the cable down the handle. Regular servo connector fits the stm8s board connector pins. I would solder 3 of the 4 and mark cable of the pin not being used (reset). Then you can mark it at both the cable and stm8s card also
fixitrod is offline
Old 06-14-2011, 10:04 PM
  #1732
cody161...
Check out my post and pics. on page 88 of this thread (post 1308). You'll see what fixitrod is describing.
:harry
Harry E is offline
Old 06-14-2011, 11:56 PM
  #1733
QuangVuong's Avatar
Trader Rating: 16 (90%+)
Originally Posted by Wuudogg
Can you show the LED mod in more detail. Where are you getting power from ?
You can get power from the positive side of the LED and any ground power port. THis will keep the LED on for as long as the radio is on.
QuangVuong is offline
Old 06-15-2011, 12:14 AM
  #1734
Buzz65's Avatar
Just curious, why the need for an LED?
Buzz65 is offline
Old 06-15-2011, 02:52 AM
  #1735
Originally Posted by merx9
Has anyone else connected this to a castle motor/esc combo i cant seem to get them to bind properly any ideas why?
I use mine with the Castle SCT system without a problem.
Indymike5353 is offline
Old 06-15-2011, 04:12 AM
  #1736
Buzz65's Avatar
I use mine with a Castle Mamba Max Pro + the Cheapie Tacon Motor and high powered fast/cheap servo. I installed a 'glitch buster' capacitor from the start and have had zero issues.
I added one of THESE from the very beginning.
Buzz65 is offline
Old 06-15-2011, 04:26 AM
  #1737
QuangVuong's Avatar
What AAs do you guys use?
Old 06-15-2011, 04:39 AM
  #1738
Thanks fixitrod and Harry E for your help. I have never soldered on a circuit board before so how big of a soldering iron do I need. I have a 30 watt and then a Hakko FX-888 that I could turn the temperature way down on.
I also use this with a Castle SCT system without any problems so far.
cody161 is offline
Old 06-15-2011, 04:57 AM
  #1739
QuangVuong's Avatar
Any soldering iron would work, just try not to burn the board when soldering.
Old 06-15-2011, 05:45 AM
  #1740
Couple more questions, do you tin the board too or only the wires? Also does the stm8s come with the required USB cable or do you have to get it separate?
cody161 is offline
