-   -   Brusless motor question... (https://www.rctech.net/forum/radio-electronics/393509-brusless-motor-question.html)
Spoold97 04-28-2010 09:30 AM
Currently im running a DBX VE. I pulled the Orion ESC (stock) out and replaced with a Mamba Max Pro. The stock motor, which is a 2800 kv Orion 550 can size is amazing...whether it be punch and/or top end. This Orion motor unfortunately is un-sensored. Im looking to pick up a new SENSORED motor (Cant stand the cogging of un-sensored), just not sure on what other motor on the market is equivalent and sensored.
Specs:
DBX VE
Castle Creations Mamba Max Pro (avg temps...110)
Orion 550 2800 kv (avg temps...115-120)
3s Li-po's
M8...spektrum converted
Upgraded front/rear ring gears
Losi module 1 13th pinon (With RR 5mm bore adapter)
46th Spur
Revised front/rear drive shafts
1/8th scale wheel adapters
ETC.
Thanks in advance!
NovakTwo 04-28-2010 10:14 AM
If you are looking for a sensored, 550 size motor Novak offers two versions: our new Ballistic 550 and our earlier HV 4.5.
Spoold97 04-28-2010 10:45 AM
So the 7.5t would be closest to what im trying to achieve?
NovakTwo 04-28-2010 01:04 PM
The installation of the 7.5 T wound stator in a Balistic 550 motor would approximate the Kv you are currently using. At this time, we are not offering a separate 7.5 motor.
