-   -   CC Sidewinder Problems (https://www.rctech.net/forum/radio-electronics/393106-cc-sidewinder-problems.html)
Feint Motion 04-27-2010 12:23 AM
I just purchased a Sidewinder for my Slash 4x4. I went and did the basic beep set up to get it going.
When it came time to run it. It suddenly had bad acceleration, motor cutting in and out, coging, and glitching. (yes my RX is away from the Esc)
I'm using the stock 7 cell that comes with the RTR slash 8.4 volts 3000mah.
Is Lipo cut off the play here? Is it enabled stock out the box? I do plan on buying the Castle link Asap.
I really hate the beep set up they use :rolleyes:
crusey_aus 04-27-2010 03:35 AM
ESC comes with auto-lipo enabled so it will be the cutoff
Can be changed without castle link, details on the castle website
Cheers
Feint Motion 04-27-2010 07:16 AM
Cheers
I knew that, I did it 2 time manuly. Still nothing. I using a mx3 2.4 fm radio. I may need to upgarde the firmware?
squatchy2009 04-27-2010 07:26 AM
mine does the same. i use lipo's and six cell nihm's with it but for some reason 7 cells will not work with it no matter what i do, get yourself a good six cell or a lipo
Duster_360 04-27-2010 08:13 AM
The default out of the box is auto-lipo (3.0v/cell) - all Castle's escs come this way.
The cutoff has 6 options and it wouldn't surprise me if you've got it on one of the others. Unless you got a Sidewinder thats been on the shelf a long time, the firmware on it should be late enough that its past the ver that had some cogging.
There will be no ques with the Link. I was using Quark escs and didn't care for the beep business either. When I got my 1st Castle esc, I ordered it with the link - one of the big reasons I switched!
Feint Motion 04-27-2010 11:50 AM
Ill try switching up the battery packs.The stocker 7 cell is still pretty brand new tho. I'm honestly leaning towards a novak balistic system now. My last system was a havok sport and I had ZERO problems.
KniteWulfe 04-27-2010 05:07 PM
What servo are you using? The sidewinder has only a 1a bec which can cause some strange glitching if you are using a servo with high current draw. If you are using the traxxas servo that probably isn't the problem though.
speedster1919 04-27-2010 07:20 PM
You never said what motor you run, For instance if you hooked up a 17.5 it will cogg like no tomorrow. Thats the nature of sensorless with high turn motors.
Feint Motion 04-27-2010 07:38 PM
Its the 5700 Motor that comes with the sidewinder..
I went out and got a new 7 cell, works like a charm, tons of power, retarded fast lol . I now have problems with long range now. I haven't charged the battery to full yet, that might be the issue. Any suggestions on fixing my range? My Receiver is far from anything and I'm still getting shutter at long distances.
-transmitter-
Airtonics 2.4 FM MX3
Feint Motion 04-27-2010 09:13 PM
lol i fixed the problem. My transmiter is bad. Time to upgrade! Mywallet>:cry:
Feint Motion 04-27-2010 10:36 PM
Just Picked this up :D
http://aztecdivingutah.com/pics/CSE010-0063-00b.jpg
Thanks for the all the help.
Duster_360 04-28-2010 03:44 AM
^^^ I love mine, it goes with me every time I go out to run!
KniteWulfe 04-28-2010 04:59 AM
It is really handy. I just wish the pins weren't exposed like that. I think I'm going to make a case so I can keep it in my pocket.
Duster_360 04-28-2010 10:25 AM
Yeah, the pins are vulnerable - I just cut down the protective sleeve it was in when I got mine, thats been fine so far. It does stay in my shirt pocket or my auto's glove box though.
This is def not for tossing in your pit bag unprotected!
