-   -   receiver problem (https://www.rctech.net/forum/radio-electronics/391907-receiver-problem.html)
hpidrift 04-23-2010 03:20 AM
receiver problem
hey guys. my receiver has stuffed up and isnt working any more so im looking to get another one. just wanted to know if i can get any receiver or does it have to be one suited for the radio controller??
the radio controller is just a normal 2 channel one
Duster_360 04-23-2010 06:50 AM
2.4GHz, FM (27 or 75MHz), AM or what??
Answer depends on what you're running.
hpidrift 04-23-2010 07:19 AM
im running a 27mhz
RC Dad 04-23-2010 08:58 AM
Then you should stick with the same brand receiver/radio if possible. Different brands have different crystal-shifts so are not all compatible.
Duster_360 04-23-2010 09:24 AM
The only one that has the signal shift diff is 75Mhz FM - reason I asked about which freq only for FM, the others it doesn't matter other than to keep FM to FM rcvr and AM to AM rcvr. Don't mix crystals - they only work in pairs from same manufacturer.
