best motor for 25amp esc?? >
Old 04-08-2010, 05:06 AM
Default best motor for 25amp esc??
hey guys i have a hobbyking 25amp esc running a 12t brushless at the moment. does anyone know if i can run a 7t motor with this esc safely without stuffing anything up?? or what the most power motor i can run on these esc's??
thanks
hpidrift is offline
Old 04-08-2010, 05:48 AM
PaPeRo's Avatar
That ESC probably won't safely work for long if you run a 7T motor with it. For a 35A ESC the limit is 9T so for a 25A esc the limit will likely be somewhere around 12T which you're already running. You could try running a 9T and see if the ESC could handle it without thermaling.
PaPeRo is offline
Old 04-09-2010, 01:19 AM
yeh i didnt think so. thanks i might try the 9t or 10t
hpidrift is offline
