-   -   protek life rx pack? (https://www.rctech.net/forum/radio-electronics/387363-protek-life-rx-pack.html)
whtpny4 04-07-2010 03:59 PM
what charge rate is safe to charge these at, no paperwork with battery, they
are 1700 mah. are they like a lipo 1000mah = 1amp charge rate? i do have a life charger. thanx, Pat:confused:
mthird 04-07-2010 04:06 PM
These are safe to charge at 3 or 4c. You should try to stat closer to 1c if charging within the radio box and to maximize the lifespan.
You may also have current issues at 4c with smaller gauge wires.
Who8mySandwich 04-07-2010 04:14 PM
1.7 amp (1C) recommended for the first 20 charges. After that up to 5.1 amp (3C).
http://www.amainhobbies.com/product_...ck-66V-1700mAh
Eagle7 04-07-2010 04:56 PM
Why pay more for the same battery A Main just puts their name on Intellects battery.
http://www.absolutehobbyz.com/produc...oducts_id=1592
whtpny4 04-08-2010 10:59 AM
thanx for the info, this is my first life pack and i just want to make sure it is done right!:cool:
AreCee 04-08-2010 12:15 PM
Do you have a charger that does LiFe or A123 batteries?
Their voltage is different than Lipos so the cutoff isn't the same 3.3V vs. 3.7. The good news is that LiFe seem to be able to take an overcharge and not blow up.
whtpny4 04-08-2010 03:22 PM
yes, my venom procharger is life capable.
