Servo problem? Need help
Just got this MRS4 which is all stock off fleabay, anyways, Was excited to get it to work. And noticed that with reverse it just turns to the L then it goes back to neutral. I am having problem driving it anyways. And I am not sure what I am dealing with. I am newbie with troubleshooting so any help will be greatly appreciated. Thanks.
Im not sure what you are trying to say, but it sounds like you are saying that when you use reverse the steering turns.
We will need a bit more info to help you here. Does forward operate normally? What electronics are in the car? |
yes, forward and turning left and right works but when reversing it automatically steers to the L. However, it just steers to the L by itself as well when going forward at times. I'm not at home right now and no access to the car. Thanks for trying to help.
another thing is if u run or nitro or EP car. if possible do provide your car model. info on the Tx & Rx. the best if u got pic so easy for everyone to assist.
Originally Posted by yral5la5h
(Post 7209781)
Got the chance to look at the car again this morning before work and it does steer to the L with forward and reverse.
BTW here's more info about the car its an HPI Micro RS4 all stock. Checked the servo but can't get the name or brand all I can see is its made in malaysia. will try to remove things later tonight or get pictures. |
Got more information on the Servo, its NES 527, and I have a JR tx. Hope this helps, I am trying to add some pics but not letting me do it. thanks
| All times are GMT -7. It is currently 06:46 AM. |
