How much of a difference does rotor diameter make?
So I ordered a 13mm rotor from my Tekin 10.5 redline motor after a pinion seized to the shaft. What I meant to get was another 12.5mm rotor like the one the motor comes with. How big of a difference will this make in my T4? What is the point of changing rotor size?
It's a lot like using a larger pinion, or adding more timming to the motor. You're going to get more a top-end speed, but less torque. You'll need to change gear ratios to adjust to the larger rotor.
Originally Posted by Foxxrocket
(Post 7195154)
My bad. Thought it was the other way around.
| All times are GMT -7. It is currently 02:02 PM. |
