-   -   Hakko 936 problem-need help (https://www.rctech.net/forum/radio-electronics/380561-hakko-936-problem-need-help.html)
Old Tech 03-16-2010 08:40 AM
I purchased a new Hakko 936 from my local hobby shop in December 2009. Only has about 10 hours (probably less) of "burn" time on it. I went to use it yesterday and it ws having trouble melting solder. When it did melt the solder, the solder would not "wet" the tip. I pulled out my temp gun and the tip only temped about 350 degrees F...climbed to about 370 when I cranked the temp knob all the way up?:confused: Any thoughts on what is going on here? Do I need a new heating element already?
Any help would be greatly appreciated.
Duster_360 03-16-2010 12:03 PM
Never had any probs with mine - here's the manual - look at pg 8 - covers checking the element - may be oxidized inside -
http://www.tequipment.net/pdf/Hakko/936e199809a.pdf
HB Moose 03-16-2010 03:58 PM
Try swapping another iron to your base unit and vise versa. Then you'll know which is defective. Bring it along to the track and we can check it out.
unsp0ken 03-16-2010 04:06 PM
What type of solder are you using?
Old Tech 03-17-2010 08:41 AM
I'll have to check exactly what it is, but it's the same stuff I've been using for years. What should I be using? Is there something specific I should be looking for in a solder?
Moose, next time we race I'll drag it along...I'll give you a heads up so you know to bring yours.
Tried the Hakko "live help" yesterday but was having issues connecting.
Duster, thanks for the link...I'll take a look.
Duster_360 03-17-2010 10:55 AM
Mine gets more than twice 350F and thats with the knob not cranked all the way over. The manual has a piece about measuring resistance between pins on the plug where the iron connects to the base. That should tell you what's going on with yours.
Old Tech 03-18-2010 07:33 AM
The solder is a lead free rosin core solder...dang it, can't recall the brand now...I got a bad case of CRS...can't remember s#!t...
I looked over the manual on checking the resistance across various plugs...tip to pin, pin to pin, etc. Not sure exactly how to do this?:confused: Sorry, I'm not too savy with things electric...which begs the question of why I choose to race electric I guess.:p
MotoGod 03-18-2010 07:45 AM
Have you tried a new tip on it? I bought a used Hakko 936 and the tip sorta worked...in a few random spots. I replaced the tip on it....it's like brand new again ;-)
Old Tech 03-18-2010 08:16 AM
I have not, but sounds like it's worth a shot.
Duster_360 03-18-2010 04:25 PM
If you have a decent voltmeter, it should have a setting to measure resistance. When they say resistance across pins 2 and 3 (example) you put the probes in pin 2 and they other in pin 3 and see what the reading is on the dvm.
If you don't have a dvm (digitial voltmeter) you should. Mine cost my $5, they're not expensive and even the cheapies are good enough. Everybody running elect should have a dvm, its a basic tool, answers a lot of questions.
simplechamp 03-18-2010 07:26 PM
Make sure to get a digital multimeter (DMM) and not just a digital voltmeter though.
Duster_360 03-18-2010 07:43 PM
Technically you're correct, but the cheapies are going to have a resistance feature, I've not seen a cheap one without. When you get into expensive, real test equip, voltmeter vs multimeter makes a diff, not seeing that with the cheap dvms, we're not talking Flukes here -
http://www.batterystuff.com/battery-...ts/YDMM05.html
http://www.northerntool.com/shop/too...ct_12496_12496
I use the Northern tool one that I got on special for $5. These are cheap and accurate enough or rc work.
Old Tech 03-18-2010 09:43 PM
I do have a cheap dmm/dvm and it does measure resistance...just never used the feature before.
I used some fine sandpaper to clean the tip and did get the solder to wet the tip...but it didn't hold the solder for long. My temp gun must max out at around 500 degrees...just says "hi" at a certain point. I decided to turn up the calibration pot abot a quarter turn in an attempt to see if the temp could even go higher than thr 300ish I was getting before. Went to around 450. Turned the pot about another 8th turn and that's when the temp gun maxxed out. Is it possible that I've been that far off on the calibration from day one? Waht temp do most of you guys use to do basic esc/motor wiring?
Duster_360 03-19-2010 08:12 AM
Never calibrated mine, but keep it set at 750 and its never lacked the heat for any soldering job, soldering batts or 10ga wires.
racer1812 03-19-2010 05:50 PM
Very bad idea. Get a new tip and never do this, but if the tip is so bad that you use sandpaper it's shot anyway so you're not hurting anything really.
Old Tech 03-22-2010 08:50 AM
Thanks racer1812. I knew I shouldn't sand the tip, but thought I'd try as I couldn't get the tip clean using the method provided in the Hakko instructions. Still trying to figure out the heating issue. I have emailed and called Hakko and have not heard back from them yet. I tried to contact them via their live help online, but can't seem to get that website feature to work. My LHS is out of tips right now, but I'll pick one up when they get them back in stock and start over. I'm a little disappointed in Hakko for not contacting me back yet...been a week.:confused:
Old Tech 03-22-2010 08:53 AM
One other question. How long should a tip last, and what would cause one to degrade?...type of solder?, temp setting?, how long you leave it on?, etc.
racer1812 03-23-2010 06:49 AM
How long? depends on all of the above. For me if I'm not using it, it's not on. Unless you hard wire your batts. (pre lipo days) I don't see a reason to have it on if you're not using it. And at the track if it's not on people don't want to borrow it!!:sneaky:
Tubaboy 03-23-2010 08:42 AM
Biggest reason for ruining a tip is applying to much pressure. The tip isn't vice grips to hold something down with a lot of pressure. Light pressure is all that is needed, just maintain contact so that it transfers the heat to the solder and connections.
I've had my iron for 4 years now, and pre-lipo days it would spend the entire day turned on. I have 3 tips and the 2mm tip is the one that is usually on the iron. It still works as good as the day I bought it.
Old Tech 03-23-2010 09:02 AM
Thanks for the..uh..tip Tubaboy. You'll be happy to know that there are no flattened out wire ends on any of my stuff!:lol: I used to use a basic 40 watt pencil iron pre lipo days. Used to keep it burning all day long on race days and never had a problem. It's been a while since I've done much soldering. I bought the Hakko because of it's good reputation and it being a station and all. I wasn't planning on having this be a regular item at the track with me.
After cleaning the tip and spending some time re-tinning it, it is working fine now. I'm still a little concerned about the heat though...not sure it's heating up to full temp.
