Having problems with a RS
Can't get the speed control to calibrate to my Tx. I have a KO Eurus and follow the instructions. After it finds neutral and chimes I pull the throttle all the way down and it just keeps beeping and the vc light blinks. I have the throttle epa @150 max, any Ideas?
Fixed!! had to reverse the throttle and servos. |
Why have the EPA so high? Have you tried with it at 100% or less?
mine did that and the lipo cutoff was set wrong for what I was using
| All times are GMT -7. It is currently 02:07 AM. |
