Mamba Micro Pro Programming
Hi All, I have a small problem...
I programmed my esc last night with the software and now when I pull the throttle the wheels keep rolling forward until I apply the brake then it stays still. revers works normally but as soon as i pull the throttle again the truck won't stop moving.:weird: i am using a JRXS3 Pro with RS receiver. I have the grip button "A" set to max as per the instructions and have cleared the radio to make sure all the other settings are normal. I re calibrated the esc to the radio three times and got the same result.:weird: I'm at a loss as to what I've done wrong.:( |
Originally Posted by newbie*
(Post 7089542)
Sounds like the thottle trim need slight adjustment now. Don't know why the software charge made it diff, but it changed it.
Originally Posted by Duster_360
(Post 7090045)
I'll give that a shot tonight after work. Thanks for the replies. |
| All times are GMT -7. It is currently 06:44 PM. |
