-   -   charge settings? (https://www.rctech.net/forum/radio-electronics/376342-charge-settings.html)
bcr500 03-03-2010 12:55 PM
charge settings?
I have a new dynamite passport ultra charger and im new to charging so i need some info on charging my packs.I have a couple of 3000mah packs and a couple of 1200mah rx packs some of which need cycled to get them back to life.So I need to know how to set this charger up to charge the packs i have thanks.
Duster_360 03-03-2010 02:35 PM
3000mah NiMhs - charge at 3amps and use peak sensitivity of 3 - 5mv/cell. If they're not getting too hot (should be around 120-130F), can try charging at higher charge rate, maybe try at 4amps.
On the 1200s, I'd start with a long slow charge at 200-300ma. After that, I'd cycle them at 1amp charging and discharging. I'd try 3 cycles to start and look at the discharge numbers. If they're still increasing, try few more cycles.
Discharge to 0.9v/cell and charge with s peak sensitivity of 3 -5 mv/cell.
burnineyes 03-03-2010 08:34 PM
That sounds perfect to me
+1
