-   -   battery load testing (https://www.rctech.net/forum/radio-electronics/376037-battery-load-testing.html)
dietDrThunder 03-02-2010 10:41 AM
How do you do it? I have the Turnigy 130W meter, but what are you guys using for the load?
burnineyes 03-02-2010 10:58 AM
I have a prop that fits a brushed motor mounted to the bench. I dont think it pulls more than 20-30A, but its what I have so it works for light loads.
crusey_aus 03-02-2010 04:01 PM
I have the turnigy wattmeter, great little device
I use it to check battery performance on my mini revo with different battery combinations
Great for showing the following
Amps Drawn
Voltage drop under load
Total Power
Just gets connected between batteries and esc
Showed me very noticeable difference between the cheap Zippy batteries and some more expensive ones rated at a higher discharge
Cheers
Duster_360 03-02-2010 04:32 PM
I guess I'm doing the same thing with my Eagle Tree onboard data recorder. I get voltage and current vs run time over a run. Its a real world type load and it tells me a lot about my setup - what the amp draw is, when its highest, when its lowest and what kind of average. I can see if lipo lives up to its C rating based on the voltage drop for a given amp demand.
jammnjeff 03-02-2010 05:42 PM
I use this on nimh do not have lipos yet just got a orion race spec charger and am ordeing lipos soon the tekin goes to 30 amp gives run time in seconds and capacity
http://i297.photobucket.com/albums/m...f/IMG_0311.jpg
dietDrThunder 03-02-2010 05:47 PM
Amps Drawn
Total Power
Cheers
Ya I'm gonna order one of those...but does it have a downloadable memory or something? How do you get the data off it?
Also, my main need is to load test batteries to compare specs to reality, and to compare battery v. battery.
crusey_aus 03-02-2010 10:34 PM
The data is reset each time the unit is turned on
Initially when plugged in it will show you the current battery voltage
Once you do a power / high speed run it will store the following
Max amps
Min Volts
Power
Mah used
Cheers
dietDrThunder 03-03-2010 08:30 AM
Max amps
Min Volts
Power
Mah used
Cheers
Thanks for that! can't wait to play with it...
