M11 VS M11X
#16
im finding them for like 330 340 but with out the second receiver so idk
#17
do yourself a favor and pick up a 2 cell lipo Rx pack for the M11X
like this one:
http://www.amainhobbies.com/product_...-Balancer-Plug
like this one:
#18
whats biggest diff from m11 to the m11x? just speed?
#19
for me it was a bit of both the speed and comfort
#21
i'm too heavily invested into the m11... 18-20 receivers
#22
i have more receivers than that, but i have 18-20 cars that i currently run.
#24
I do not own the m11x, but to me the biggest down side is the radios RXs. If you own multiple cars, like most of us do. You will be dropping quite a bit of coin to get RXs in your cars. The only RXs that the m11x can use is the FHSS2 and FHSS3. They are pricey and hard to find used.
Other than that and price, the m11x seems to be above every other radio in the market IMO. Is it worth the coin? In my opinion, no.
#25
If you take off the 2,4G module and receiver and you get a Mhz receiver you can use the radio as Mhz radio?? Thats for both radios question..
#26
The M11X has an inbuilt module, so no, it is 2.4ghz only.
I also have a question...
The 4th channel.
Is it fully programmable/usable?
I Emailed Airtronics.net and the reply said they are but after reading the manual it doesn't look it.
Looks like it is for brake mixing only really, although from what I could understand you can set a certain button to a channel, so could the 4th channel still be used to control a servo or lights or even a kill switch?
I just bought the MX 3X and was thinking that if I ever needed/wanted a 4th channel I could get the M11X and keep the MX 3X as a backup/spare transmitter.
I didn't really want to invest in the Futaba range mainly due to being a bit more expensive and what seems like poor after sales service.
I seriously considered KO Propo but for some reason didn't (the Sanwa having more output power helped, sick and tired of range issues).
Spektrum I decided against because although I had heard many great things about them but also quite a few not so great things.
The 4th channel.
#27
That means i can do it in M11??
#29
#30
hello everybody,
I plan to buy a M11 with the fhss-2 module.
can I use a lrp c3 fhss receiver with this radio?
thanks in advance
thanks in advance
