1P vs 2P
Not sure what kind of a debate this will start but here goes,,is a 2p battery equal to a 1p,I understand that a 2p is actually 2 cells in series and then 2 in parallel,but what I want to know is,if the 2s2p battery will perform as a 2s1p battery?Lets say if I ran a 2s2p 30c 5000mah pack,would it be the the same as running a 2s1p 30c 5000mah pack.Is the 2s2p going to deliver the same amps and runtime safely,going to run these batts in an E Revo.
exact same preformance...
On a similar topic, 2S lipos typically have a balancing port which makes sense - each cell is charged (or discharged) independently from each other.
However, saddle pack lipos are typically 2S2P or even 2S3P for 5200+. So if you balance charge, you're effectively charging 2/3 cells at each point. Doesn't this kind of defeat the purpose of balance charging in the first place? |
Originally Posted by scrawl
(Post 6914268)
However, saddle pack lipos are typically 2S2P or even 2S3P for 5200+. So if you balance charge, you're effectively charging 2/3 cells at each point. Doesn't this kind of defeat the purpose of balance charging in the first place? no, because of the way its wired, if 1 lipo cell(in parallel) starts to overcharge, it will automaticly discharge to help bring the other cells up the the right voltage |
Originally Posted by Craig J
(Post 6913008)
Originally Posted by RC Dad
(Post 6915967)
Two 30c cells in parallel will simply offer more run time. A that discharge capacity you won't notice much if any difference in punch and the voltage (rpms) remain the same.
| All times are GMT -7. It is currently 11:12 PM. |
