-   -   novak gtb programming trouble please help (https://www.rctech.net/forum/radio-electronics/358654-novak-gtb-programming-trouble-please-help.html)
gnatsum69 01-08-2010 01:24 PM
Hey there got a novak gtb 2nd hand and i am setting up i a xxxt can't get reverse to work have gone through the instructions to change profile to #5 and done one touch setup but no luck any ideas.
michael
NovakTwo 01-14-2010 10:16 AM
michael
It probably has been damaged.
Because I am not part of Novak's technical support group, I suggest you email [email protected] with your question, Our regular CS/Tech Support hours can be located here. Before emailing, take a moment to review the instructions (trouble-shooting guide) originally included with your Novak Item:
Novak Instruction Downloads
Trouble-shooting TeamNovak's One Touch™ Speed Controls
Please make your initial email as detailed as possible. Include:
~ warranty claim?
~ speed control (brand/model)
~ motor (brand/wind)
~ rotor (old/new)
~ connectors used
~ servo (brand/model)
~ radio system (receiver/transmitter)
~ vehicle & gearing
~ battery, brand (c rating/capacity)
~ lipo cut-off, on/off
~ any external modules (BEC/brand, Glitch Buster)
~ other important info: water damage, corrosive chemical sprays, excess heat, etc
The more information you provide in your first email, the more quickly tech support can offer you assistance.
Clairvoyant16 01-14-2010 02:05 PM
SAME THING HAPPEND HERE
MAKE SURE ITS ALL PLUGGED IN RIGHT INTO THE RECEIVER!! OR IT WONT WORK
the mighty thor 01-16-2010 09:20 AM
your instuctions might be for a different series of speedo they updated them from time to time i have like 10 gtbs and there are a lot of differences in them i have one that has reverse on prog 4 you might try that
good luck
the mighty thor:tire:
gnatsum69 01-17-2010 02:07 AM
good luck
hey man cheers for the input but have googled instruction and can only find the same ones online that i already have.
Hey guys thanks for all your input. turns out i am stupid i just wasn't holding the button down long enough for all 4 leds to light up whoops. now it works fine. thanks again
