DX3S Trigger/Throttle not working
Has anyone ran into this? Am I just not seeing something correctly?
The run down. I run 3 vehicles at the moment on my DX3S. I got to the track today. Installed a new motor into my SC10. Ran a pack through it no issues. Races start... I switch over to my B4. staged to take over the drivers stand I switch on the radio (go to the B4 model), turn on the car and nadda.. I didnt see any lights changing on the ESC so I did a quick ESC/TX calibaration and it seemed fine. I started my pre-heat hot lap and the car died about 30 feet from the drop in point. (which in the process broke a ball stud) - I go back to my pit table and begin working on the ball stud issue... My next class is due up shortly so I get the T4 ready... No Throttle at all... Now im thinking my ESC's all got alzhimers or something.. Check the SC10.. now it has no throttle either.. Steering works fine on all vehicles. If you push the trigger for brakes the ESC shows it is breaking. (LRP Sphere's so no reverse) I rebound, recalibrated all receivers and ESC's. Not working. I plugged each ESC into it's respective RX's Steering port and turn the wheel... Powers the motor just fine. I have one Telemetry RX, 2 non Tele Rx's... So no, I did not plug something in wrong.. I bound to someone else Rx. no go. I had someone else Bind there DX3R to my Rx. No issues, worked fine. HAS to be something in the radio at this point, right? I know this is long winded.. worded... Thanks for reading it through. Reese |
bump for an interesting problem
Well, it's on the way back to Horizon now.. let's see what they can come up with..
| All times are GMT -7. It is currently 06:01 AM. |
