-   -   ExtremeLink 2.4g system, good or bad? (https://www.rctech.net/forum/radio-electronics/355159-extremelink-2-4g-system-good-bad.html)
Team Ash 12-27-2009 04:59 PM
I am after some advice.I am looking at buying one of these modules/receiver systems for my radio. It is used and the price seems right.
Anyone know much about them? How do they compare with spektrum?
Terry
skyblueblue 12-27-2009 07:50 PM
wat tx u using? I had the extremelink on the evo9. Personally i had no issue but few of my flying buddies said they got into lock out. i don't do 3d either so i can't comment much on the relaiablity.
There is another Assan hack module which you may want to consider.
Team Ash 12-27-2009 10:52 PM
jr
It comes in a JR-R1 radio for rc cars. I have been told it is good but sometimes is hard/slow to bind.
Terry
skyblueblue 12-28-2009 02:23 AM
u talking about the XPS extreme link right?
U can check out the binding procedure here
The receiver programming button is located on the circuit board and need to be depressed by blunt object
skyblueblue 12-28-2009 02:25 AM
I have 4 rx and i bind them easily.
Team Ash 12-28-2009 02:19 PM
Thank you
That is the same system. Thanks for the link.
In the guide it mentions you must keep the antenna wire away from metal including carbon fibre. Two of the cars it will be used with are all carbon fibre and alloy. Will it still work ok?
Terry
VasMan 12-28-2009 06:41 PM
I used to have it for aircraft, and my main reason for getting it was the ability for telemetry. Unfortunately this feature never really materialized, so I switched to Spektrum (aircraft) as more BNF kits started coming out. I still believe that XPS has one of the better products out there (most of the recent offerings are user programmable/upgradable), but the lack of telemetry and tiny receivers was the reason for me not sticking with it.
http://www.rcgroups.com/xtreme-power-systems-483/
Vas
skyblueblue 12-29-2009 02:28 AM
Terry
My heli is full CF and bling, didn't have any problem. My antenna is also like a stud. Not the wire type.
It's always safe to do a range check before running anyting and make sure fail safe is on when signal is lost
Team Ash 12-29-2009 11:11 PM
ExtremeLink
Thanks for the help. I am sure it will be great. I will definately do a range check but it only has to reach about 40yards. The only sygnal problem I think I will have is between my brain and hand. :) Hopefully I will find out soon as it's on it's way.
Thanks again for everyones help
Terry
