-   -   Fixing antenna on RX? (https://www.rctech.net/forum/radio-electronics/352710-fixing-antenna-rx.html)
bigbeej 12-17-2009 10:42 AM
Is it possible to fix the antenna wire on a spektrum RX? Mine has been sliced a little near the bottom where it goes into the casing.
stiltskin 12-17-2009 12:36 PM
They are easy to replace with a 25 watt soldering iron and a new antenna wire. Cut the wire to the same length and solder in place. If the wire isn't damaged (except for the plastic coating) you can put some shrink wrap around it.
