-   -   Lrp Sxx tc issue (https://www.rctech.net/forum/radio-electronics/352575-lrp-sxx-tc-issue.html)
Panic09 12-16-2009 10:05 PM
Lrp Sxx tc issue
Hey guys, need your input,,,bought an LRP SXX TC speedo ... Steering works fine but no throttle. LED status indicates its working - .I have Re-setup the ESC, no results. I noticed though that motor do not Beep anymore when entering setup!... Changed motor,changed sensor wire - but still no throttle, All motors work well with other ESC's and my wiring is properly connected...any ideas? is the esc useless? or i m doing something wrong?
Tnx
RC Dad 12-17-2009 10:28 AM
what voltage are you running? sounds like what the 1s lipo guys are experiencing without the BEC
Panic09 12-17-2009 12:59 PM
Im using 7.4v lipos , 2cell....
revracr909 12-17-2009 01:31 PM
Check if the ESC is pluged into the right spot on the reciever.
onroad dude 12-17-2009 03:36 PM
may seem like a odd question but does the fan still work?
Panic09 12-17-2009 05:01 PM
Yes everything is pluged in correctly...
Toh WL 12-17-2009 09:13 PM
My suggestion is to bring it back to the LHS you brought to test out. If your ESC is proven defective. You still got 120days warranty.
