DSM2 Recievers
Does anyone know of the exact model names for the dsm2 telemetry compatable receivers? Looks like I have to swap out my older spektrum rx's for the newer dsm2 ones:(
Originally Posted by maxair45
(Post 6712932)
SR3000 SR3001 SR3300T Now the newer DSM2-equipped transmitters are also compatible with DSM receivers, such as the ones above. So if you've upgraded to a DX3R, DX2S, DX3S, etc then your older DSM receivers will work with them. |
My goal is to run telemetry on my dx2s(or 3s if I can work out a deal with a guy on here). I have a sr3000, sr3001 and a losi spektrum receiver. I now know the first two are telemetry compatable but is the losi receiver?
Thank you for your help |
No, the Losi Receivers are not. That's why the 8IGHT 2.0 RTR, 8IGHT-T 2.0 RTR and LST XXL all include the SR3300T.
Very good to know. Thank you for the info. While where on the topic does anyone know the release date of the dx2s? I have no idea I have taken a bit of a break from rc and i'm a little out of it.
One last question the upgrade wraps for the dx3s will fit the dx2s correct. I believe it is the same case but minus the third channel, 10 model memory, and punch control.
You are correct sir!
Originally Posted by RCGaryK
(Post 6713000)
Now the newer DSM2-equipped transmitters are also compatible with DSM receivers, such as the ones above. So if you've upgraded to a DX3R, DX2S, DX3S, etc then your older DSM receivers will work with them. Does this work in the other way around, that is will DSM transmitter work with DSM2 receivers? thanks oze |
No
DSM2 transmitter with all spektrum branded recievers. DSM1 transmitter with DSM1 recievers only. |
| All times are GMT -7. It is currently 01:11 PM. |
