vxl esc and motor problem
just bought it used on this site and when i got it didnt work.
thought it might be the battery so changed that still not working. everytime i wiggled the wires to the motor it would jumpo (work ) but stop again. also noticed when i unpasked it the motor smells burnt not to good of a sign. somethings wrong with this set-up. so after disconnecting the motor a few times i noticed that the terminal for the motor (yellow) on the esc was a little lose. had to be a bad soldiering job. figure i had to get inside the esc to look closer at it. before i pulled it apart i plug the wire back in one more time. this time the terminal came out on the end of the connector. opened it and it had to be the problem. resoldiered it and put back together. works in forward but no reverse. tried all three program for the esc and nothing is working to get the reverse to work again. just wondering if it would be the motor or is the esc switch from forward to reverse probaly bad. has this happened to any body else beside me. taken with my cell so not the best quality! http://media.use.com/images/s_2/af03...859ed264_1.jpg http://media.use.com/images/s_2/af03...859ed264_2.jpg http://media.use.com/images/s_2/af03...859ed264_3.jpg http://media.use.com/images/s_2/af03...859ed264_4.jpg http://media.use.com/images/s_2/af03...859ed264_5.jpg |
| All times are GMT -7. It is currently 08:25 AM. |
