-   -   M11X QUESTIONS (https://www.rctech.net/forum/radio-electronics/339263-m11x-questions.html)
pink_sleeve 10-26-2009 07:52 PM
M11X QUESTIONS
Is the M11X substantially lighter then the M11's? Also can you run 7.4v unregulated through the new FHSS-3 rx's :confused:
dameetz 10-26-2009 09:25 PM
From the manual it says, input voltage 4.8v-6.0v, so I guess you have to put regulator in between if you want to use LiPo.
iBok 10-26-2009 10:26 PM
Yes. Please see this thread..
http://www.rctech.net/forum/radio-el...-m11-m11x.html
M11X is 127g lighter which is equivalent to the weight of about five AA batteries.
Apex 10-30-2009 04:44 AM
As long as the speedo your using regulates 4.8v to 6.0v to the receiver and servo you'll be fine. If you're using this in a gas car, then you might need a voltage regulator.
