How to solder correctly (a not so brief lesson) >
Like Tree31Likes
Old 05-04-2019, 08:46 PM
  #616
Trader Rating: 19 (100%+)
Not to revive what is already an awesome sticky.
Tip Tinner renews the plating on tips. So as long as you are proactive your tips should not ever wear out no matter what company makes them.
Dave_S likes this.
Juglenaut is offline
Old 05-04-2019, 08:49 PM
  #617
Dave_S likes this.
Old 05-04-2019, 08:56 PM
  #618
Originally Posted by Rutters
Need advice on most suitable solder for this purpose. Just ordered some with 305c melting point not sure of make up. Any advice welcome.
Rob
solder suitable for comm tabs, silver solder 3% plus, small scale brazing skill a plus.
A minimum of 450F melting point on a 10 turn brushed.
Old 05-04-2019, 09:20 PM
  #619
Motor commutators, I am giving up some of my old secrets with this one:
Kester Aquabond paste or solid solder. Use no clean flux, the paste if you are lucky to find doesn’t need flux.
With the paste you you will need a small butane torch, with solid you will need a 70 watt plus iron.
Kester aquabond has a melting point of 495F
Old 05-05-2019, 11:33 AM
  #620
marine6680's Avatar
Never wearing out is a stretch, but you can make them last a long time.
The plating is going to react to the solder and O2 in the air, just at a slower rate. Keeping the tip clean, tinned, and at reasonable temps slows down the process.
Dave_S and the rc guy like this.
marine6680 is offline
Old 05-05-2019, 05:22 PM
  #621
One should not ever drag solder either.
Old 05-05-2019, 06:03 PM
  #622
Dave_S's Avatar
Not sure it's posted in this thread, but in a pinch you can make soldering iron tops from solid copper wire. You can make custom shapes and what not. They work great.
Dave_S is offline
Old 05-22-2019, 02:59 PM
  #623
Garet Jax's Avatar
Trader Rating: 112 (100%+)
Default Soldering the ESC to the motor without touching the wire?
Hello all,
How do I solder the ESC wires to the motor without touching the iron to the wire? There does not appear to be enough room under the 3 platforms to place the soldering iron.
Specifically I will be soldering to this motor.
Thanks.
Garet Jax is online now
Old 05-23-2019, 09:12 PM
  #624
marine6680's Avatar
Originally Posted by Garet Jax
Hello all,
Thanks.
Ypu solder to the outside... It looks like the silver areas are the solder pads, exposed and easy to get to.
Old 05-24-2019, 11:23 AM
  #625
EbbTide's Avatar
Trader Rating: 39 (100%+)
Hello all,
Thanks.
To expand on what was said above, you just need to pre-tin the wire, and the terminal which looks to be done already. Then put a little tin on your iron, and touch the iron on top of the wire pressing down onto the terminal. The heat should flow with the solder on the iron, it'll heat the wire, then it'll heat the terminal.
EbbTide is offline
Old 12-31-2019, 07:58 PM
  #626
Dave_S's Avatar
I feel like this would be pretty bad QA fail.
Dave_S is offline
Old 01-07-2020, 08:29 AM
  #627
frewster's Avatar
That bottom wire?
frewster is offline
Old 01-07-2020, 08:48 AM
  #628
Dave_S's Avatar
Originally Posted by frewster
That bottom wire?
in my opinion all the joints looks kinda questionable for professional product, but thing that stood out is it looks like flux residue was left on solder joints from 3 main wires.
Dave_S is offline
Old 08-09-2021, 10:25 AM
  #629
DesertRat's Avatar
Soldering is apparently getting worse. TO THE TOP OF THE THREAD!!!!
DesertRat is offline
Old 11-24-2022, 03:08 PM
  #630
ta_man's Avatar
Trader Rating: 168 (100%+)
Hello all,
Thanks.
You are supposed to solder the wires to the TOP of the platforms, not underneath.
ta_man is offline
