power supply
I am a LiPo noob, can you please help me find a power supply for my Team Losi MultiPro Intelligent Li-Poly Balance Charger, also im in Australia so it has to be 240v and have a connector like this...
http://rsc.anu.edu.au/watoc08/images/plug.jpg |
This one should be more than enough to power your charger:
http://www3.towerhobbies.com/cgi-bin...?&I=LXVCK9&P=7 You can just get an adapter from your local hardware store so you can plug it in to your wall socket |
if you wanna go cheap like me, I use an IBM thinkpad laptop power supply with mine. Mine is a 4.5 amp PS, so I don't charge over 4 amps. I'm sure you can use an Australian version of that PS if you can find one on Ebay. Just verify the amp output is sufficient on the PS before going that route.
Cheers! |
i got my charger today so now i need a power supply preferably a laptop style one 11-18v and 5amps. Also it has to be center pin positive+. Thank you please help
| All times are GMT -7. It is currently 06:31 AM. |
