-   -   cheapest power supply (https://www.rctech.net/forum/radio-electronics/335167-cheapest-power-supply.html)
mach1rustler 10-12-2009 01:05 PM
What is the cheapest poer supply that I can get away with on my Triton charger. All I am charging at the moment is my nitro stuff which is a glow igniter 6 v hump pack and 12v starter box battery
iBok 10-12-2009 03:25 PM
MRC RB970 10A 12VDC Power Supply - $25
http://www3.towerhobbies.com/cgi-bin...&I=LXVCK9&P=ML
MRC RB982 Power Supply 10A 15VDC - $45
http://www3.towerhobbies.com/cgi-bin...&I=LXVCL0&P=ML
mach1rustler 10-12-2009 04:57 PM
How do you know what amp power supply that you need. Its obvious the power supply has to supply 12 volts. I am just curious about the amps.
viper7016 10-12-2009 11:50 PM
Volts x Amps = Watts
So you need to find out the max wattage of your charger and/or what packs you'll be charging and go slightly above that.
For example my MRC 989 is a 106w charger.
12v x 8.83a = 106w
So a 12v 10amp power supply would be enough. It comes with a 15v 10amp power supply.
Here are some examples of common lipo batteries and the max amperage my charger could charge them at.
2S 7.4v x 14.3a = 106w
3S 12.6v x 8.41a = 106w
4S 16.8v x 6.3a = 106w
However my 989 has a max charge rate of 10amps.
I hope this helps you out.
viper7016 10-13-2009 12:05 AM
If this is your charger then it is 90watts - http://www3.towerhobbies.com/cgi-bin...&I=LXMAJ0&P=ML
90w/12v=7.5amps
These are some of the cheapest high amp power supplies I've found, and I get my batteries from them. You need to register and log in to see the lowest prices.
Always get the EMS Express shipping and it will take about a week to get.
$50 - http://hobbycity.com/hobbycity/store...idProduct=9205
$40 - http://hobbycity.com/hobbycity/store...idProduct=6879
$30 - http://hobbycity.com/hobbycity/store...idProduct=8592
I'm planning on grabbing the 25a one on my next order, so I can run more than one charger off it.
chrisfrom619 10-13-2009 04:31 AM
If you are in a tight budget like me I would use a old CPU power supply which gives a great power I ran 2 of my ice charger a fan and a tire warmer at the same time. You just have to look it up online how to convert one. I got mine locally for 5 bucks from a local rc guy here but it's already made when I saw how it was converted it was pretty simple.
gimpex 10-13-2009 11:15 AM
I agree - PC power supply unit.... thebasic ones are 300W , plenty enough
If you need a link , let me know , but google will help. Just remember
1) connect s many of the 12v and 0v together for best connections
2) i think its the orange wire which needs to be hooked up to black to power up
As a bonus you can have a 5V supply too if needed
Not best looking , but you can doll it up.
wingracer 10-13-2009 11:32 AM
For what you are charging, 10 amps is plenty. Even if your charger is capable of putting out say 300 watts, if you never charge anything that high you will not need a 300 watt supply. So unless you intend to charge 3 or 4s lipos at 10 amps or more, a 10 amp supply will be enough. The nice thing about higher output supplies is that you can run multiple chargers off of just one supply.
The tiny little supply I use for charging all my nitro related equipment is only 8 amps.
The Captain 10-13-2009 08:03 PM
+1 on the PC power supply.
viper7016 10-13-2009 09:18 PM
Keep in mind that a 300w PC power supply is not going to put out 25amps at 12v, that wattage is for every circuit put together.
The Captain 10-13-2009 09:43 PM
But if only one "circuit" is drawing 25 amps, it will be fine. Unless he is trying to use the power supply powering his PC (which is NOT recommended) he should be fine.
