-   -   SR3000 Problem (https://www.rctech.net/forum/radio-electronics/335125-sr3000-problem.html)
CBHVR6 10-12-2009 10:07 AM
SR3000 Problem
Ran my revo last week, no problems at all, turned it off. Went to run it today, turned my dx3s on, plugged my packs in, esc arms fine but steering keeps twitching. Green light on receiver comes on then goes off and back and forth. No throttle at all, and like i said steering only twitches on its own. I'm guessing my receiver is dead. Its weird though, i didn't change anything at all. Any help guys?
bigde2001 10-12-2009 08:12 PM
Try trouble shooting by removing throttle servo and test steering. This way you can tell if it a servo problem.
loopedout 10-12-2009 09:52 PM
Try to re bind it first.
CBHVR6 10-13-2009 04:40 AM
Didn't do anything to it, just turned it out this morning and it works. So i don't know if it fixed itself or what.
I can never get it to rebind. When i hold the button down nothing happens. Whats the proper way to rebind it? because i can't get it to work right
RC Dad 10-13-2009 09:57 AM
spektrum instructions
1. Make sure the transmitter and receiver are turned off.
2. With the receiver off, press and hold the bind button on the receiver.
3. Turn on the receiver while holding the bind button.
4. Release the bind button when the LED flashes green.
5. With the transmitter off, place the transmitter sticks and auxiliary channels in their desired fail-safe positions, normally brake and straight ahead steering.
6. Press and hold the bind button on the transmitter module.
7. Turn on the transmitter while holding the bind button.
8. Release the bind button after the green LED flashes.
Observe that after several seconds the LED on the receiver and the LED on the
transmitter will quit flashing and remain solid, indicating that the binding process
was successful. Once binding is complete, the system will automatically connect.
CBHVR6 10-13-2009 10:34 AM
thanks, i'll give it a try
