-   -   Tinned Flat Copper Braid vs desoder braid (https://www.rctech.net/forum/radio-electronics/332013-tinned-flat-copper-braid-vs-desoder-braid.html)
OfnaJoe 10-01-2009 04:53 AM
Can the pro-wick desoder (sp) braid be used instead of a Tinned Flat Copper Braid ?
I am building some 3000mah AA receiver packs and have the pro wick braid and it looks just like the 1/4 braided wire.Or should I just get the Flat Copper Braid ?
Thanks Joe
Duster_360 10-01-2009 12:05 PM
If I understand what you have, thats the same stuff I used for making a123s pacs and it worked find in those - copper braid. Some one on RCGroups tested it to way more amps than either you or I will ever run thru it.
OfnaJoe 10-01-2009 02:42 PM
It's copper braid but has rosin on it to wick the solder off of a joint, I was going to clean the rosin off and use it for my RX packs,.
Thanks Duster, I thought you might respond!!
