SMC LiPo receiver pack
I was looking for a light, compact Receiver pack, and I found this:
http://www.ssl-stormerhobbies.com/pics/smc450rcp.jpg Extended Product Information: Now you can put a self-contained lipo receiver battery pack in your 1S Lipo 1/10 or 1/12 pan car to power your radio system easily and affordably. This small, lightweight unit mounts easily and is protected by a hard shell case. Separate charge lead means you don't have to unplug it every time you need to charge it. Built in switch for easy wiring. Voltage output: 7.4v nominal (requires voltage reducer for most installations) Size: 43 x 28 x 20mm Weight: 32 grams Would this be enough to power a (just one) Hitec 7955tg for 20 minutes, through a Spektrum receiver? |
No, you need something with more milliamps.
like around 1200 or so
| All times are GMT -7. It is currently 09:41 AM. |
