Blinky Balancer or ???
Hey guys, I have this god-for-saken SMC battery that I cannot find a balance plug that fits it. I have a Hyperion 606i charger, and these two balance plugs HP-LB10-XH ; HP-LB10-HP. charger Anyways the SMC Battery has 6 ports on its balance plug. I don't know what to get but this battery needs a balance before I can charge it next, the cells are pretty different at the moment.
Is a Blinky Balancer what I need? Battery: https://www.ssl-stormerhobbies.com/c...s&pn=SMC5040SC http://www.spcracing.com/index.php?productID=85 Blinky: http://www.astroflight.com/index.php...index&cPath=34 or ??? Thanks |
This says that lipo uses jst-xh or align style balance connection -
http://www.spcracing.com/index.php?productID=85 I use a pair of Hyp chargers and have that adapter (as well as all the others) - its supposed to work with that lipo but my 4S connection only has 5pins, not 6. The TP adapter HP-LBA10-TP) has 6 pins, but its a much smaller receptacle and wouldn't fit something the size of the jst-xh male end. Somethings changed, you need t get in touch with SMC and see what they can tell you. You have the 'correct' adapter per the catalog. |
| All times are GMT -7. It is currently 07:21 PM. |
