-   -   need from help how can bind and setup fail safe Airtronics mx3fg (https://www.rctech.net/forum/radio-electronics/325629-need-help-how-can-bind-setup-fail-safe-airtronics-mx3fg.html)
xsxboy 09-07-2009 05:11 PM
So i have MX3FG 2.4 and i wanna bind transmiter and receiver and setup failsafe(for electro model)
Who can tell me how, i haven`t manul it`s second hand.
Thank you
LabRat99 09-22-2009 06:22 AM
Manual is available here
EvilDylan 09-26-2009 12:12 PM
Thats not for the mx-3fg
thats for the mx-3 which does not use the fhss-2. mx-3fg uses fhss-2
Darrel Smeltzer 09-26-2009 05:27 PM
1) turn power on the radio 2)push down and hold binding button on rx 3)turn the power on to the rx ,keep pushing down on rx binding button release after 2 or 3 sec. 4) push and hold button on tx for 2 sec. then release binding should be complete . fail safe will be set at nuetral hope this helps
VR6T 01-24-2010 04:02 AM
i got MX3FG that currently used with my LRP esc...
how do i bind it with my Mamba Max esc since it required 50/50 throttle/brake ratio to set up the esc while MX3FG is set to 70/30..
what should i do to change the 70/30 ratio to 50/50?
thanx in advance
