is this the connector i need for zippy/traxxas
will be ordering a couple of zippy 3S 1800mah to run on my erevo 1/16. i want to run them in parallel.
are 2 of these what i need to go from the zippy's dean to the traxxas parallel harness?
Traxxas Female - Tamiya Male
can someone clear up which connectors i need?
Believe it will be traxxas female to deans male. Tamiya is a whit eplastic block that you don't want to have anything to do with (they melt easily). You need the deans male to mate with the deans female that comes on the lipo. Then the traxxas female to connect to the esc.
Looking around, I don't see one. you may need to do this in 2 pieces - an all deans parallel adapter, then a deans to traxxas adapter. Be simple to build one if you can solder and have the equip.
