-   -   Receiver pack discharge rate. (https://www.rctech.net/forum/radio-electronics/324628-receiver-pack-discharge-rate.html)
Ian C 09-03-2009 06:42 AM
Could anyone suggest a suitable discharge rate for 1600mah, 6V, 5 cell NIMH reciever packs please?
And would you use the same discharge rate when cycling a new battery?
Thank you!
RC Dad 09-03-2009 09:19 AM
I would stay between .5 and 1 amp for discharge, which will take 1-2 hrs to empty the pack.
Duster_360 09-03-2009 04:33 PM
^^^ +1
I've typically use 1amp as a disch rate for rx pacs. New, I might use less depending on how hot the cells were getting. I cycle mine at 1amp both charge and disch, 3 cycles and the charge/disch mah gets very close to repeating so thats as good as they're going to get.
nazwenhome 09-03-2009 08:52 PM
me too. every time before charging :)
Ian C 09-04-2009 03:05 PM
Brilliant, thanks!
And what is the minimum cell voltage that the packs should be discharged to? As far as I know you don't empty (towards 0V) the pack RC Dad?
