-   -   DIY Power Supplys (https://www.rctech.net/forum/radio-electronics/324574-diy-power-supplys.html)
killatoyota4569 09-02-2009 10:13 PM
DIY Power Supplys
Hey guys I was searching around the net on making your own PSU. Now I have here a Xbox Psu that its OutPut is 150watts the 12v rail is @12.1A and the 5v is @ 1A ...... What do you guys think? It will work? Also inside was 3 black, 3 yellow, 1 red, and 1 blue wires. Im thinking that I gotta put a 10 watt resistor between the red n blue wires? And I should be good for my 2s lipos under 5000 mah?
I also have one that is 203 watts 12v @ 16.1A
chuck_thehammer 09-04-2009 04:54 PM
Do not try this.......!!!!!!
Lipo's require smart charging... constant amperage and constant voltage charging.. with the proper voltage cutoff...
DON'T
Cammer 09-04-2009 05:06 PM
DON'T
I think he means to power the charger with.
racer1812 09-04-2009 09:50 PM
Why go through all the BS to build one? Just buy one and be done. While you're trying to find a way to power your chager I'm turning laps figuring out how to kick your a$$.:rolleyes: That's just my $.02 for all you MIT grads.:p
snowbeaverking 09-04-2009 09:55 PM
I have seen t done real cleanly out of a PC power supply it had female banna plugs dremmeled into and every thing I can't remember what site I say it on though
Brandon_oma#692 09-04-2009 10:45 PM
free power supply vs spending money on one maybe?
msbeckysboy 09-05-2009 01:54 PM
ATX Desk top power supply - converted rc charger power supply
This is what I was shown by an engineering frind of mine .
And you probaly have one at home right now .
If not , you can build this one for about 20 to 25 dollars .
Dual 12 volt 20 amp rails , 5 volt ,7 volt , can be configured 17 volt and 19 volt with the combined amperage from the 5 volt 12 volt rails , or the 12 and 7 volt rails .
http://www.wikihow.com/Convert-a-Com...b-Power-Supply
msbeckysboy 09-05-2009 02:06 PM
3 Attachment(s)
Here is something from my starting of this conversion .
It is STUPID SIMPLE to complete .
Keep you money in your pocket , educated your self .
Greg
killatoyota4569 09-05-2009 08:47 PM
You guys are all wrong.
I have a xbox 360 power supply and IT DOES WORK!!!
I dont know if it has enough power, but It did work and charge my battery. There was 3 yellow wires, and 3 black wires, thats the power and the ground. then you have red and blue, just connect them together, and BAMN!!! there you go you have a power supply,. I will make pics to show you guys it works.
I just need more info on the amps, and the power one charger needs. thanks
msbeckysboy 09-06-2009 04:30 AM
The power supply you are refering to has the output written on the adapter .
The current draw of your xbox is about 1000 milli-amp.
I am sure if you over load it , it will get hot .
There should be a warning written on the power supply about overload , heat and the possibility of a fire risk .
I explained this to my 5 year old , there is a snake in the wall behind that plate .
Given the chance it will bite you .
He learned the hard way .
:eek:
wingracer 09-06-2009 05:10 AM
The power a charger needs depends on what you are charging and at what amps. I can charge a 1s lipo at 5 amps and it only draws about 2 amps from the supply (my power supply has adjustable voltage, volt and amp meters). 4 cell NiMH at 5 amps draws about 5 amps. 6 cell at 5 amps draws about 6 amps. A 2s 300mah pack at .3 amps doesn't even move the meter :D
racer1812 09-06-2009 11:21 AM
:eek:
Don't mean to laugh but that is funny.
msbeckysboy 09-06-2009 03:48 PM
The real funny of that snake bite was this .
For about two weeks he could not sleep or sit still .
I was wondering if the boy needed some ritlen or something .
He has a pace maker , and once a month by telephone , we have a machine the heart center checks it for beats .
It had an abnormaly high rate of beats .
The shock caused the pace maker to reset it,s self . And now it was at a rythmn of a sprinters pace .
It was reset by the center and life went on .
Needless to say , he tells everybody about that snake in the wall .
And his pace maker .
And his heart beeping real fast :eek:
Greg
jolson88 09-06-2009 03:49 PM
Based on this post, I just finished doing this today with a power supply I had at home out of a computer in a closet collecting dust. It works, and is dead simple to do! An absolutely great way to save money rather than going out and buying a power supply from Radio Shack or somewhere else (that will set you back more money, for sure).
Since I didn't need all the various combination of voltages and was fine with the power supply being off if there was no load on it (e.g. a charger or some other device hooked up to it), I did what the guy did in the embedded video at the page above. I didn't put any fancy "posts" on the PS, didn't incorporate another switch or LED (the existing switch will work fine), etc. The only things coming out of the back of the case are four black wires (ground), four red wires (5v), and four yellow wires (12v). Each same-color grouping of four is then soldered to one alligator clip (so three clips in total).
Because of this approach, I had to do zero modifications to the power supply case at all, and I just used the various gear I already had lying around. So, in total, $0 spent. That's a price I can get behind :) (and perhaps more important, the Wife Acceptance Factor is very very high :lol:).
wingracer 09-06-2009 03:54 PM
Yeah I might have to try this build. The power supply I have used for the last 20 years won't work with some new chargers, since it puts out a tic over 15 volts. Plus I have another PS that drops below 11 at higher charge rates. All my old chargers never cared but some of the new ones just start beeping errors at you at those voltages.
