Thunder AC6 Smart Lipo Charger to Charge SMC??  Help Please, Thanks >
Old 08-17-2009, 07:51 PM
Outtacontrol58's Avatar
Trader Rating: 92 (98%+)
Talking Thunder AC6 Smart Lipo Charger to Charge SMC?? Help Please, Thanks
Will this charger charge the SMC 7.4v 5200 Lipo? I really like this charger. Please let me know cuz i dont have a charger as of right now.
http://www.hobbypartz.com/thac6smbachw.html
Outtacontrol58 is offline
Old 08-18-2009, 11:30 AM
Thumbs up Anyone??
Anyone got any suggestions??
Old 08-20-2009, 07:39 AM
johndayo101's Avatar
Trader Rating: 128 (100%+)
i have the same lipo as you have and charge it with ac6 with ps. this charger is a winner. cheap and can balance your batteries too. theres is an option in the charger mah cutoff. i adjust it to 5200.
johndayo101 is offline
Old 08-20-2009, 09:20 AM
Exclamation
it will charge that battery at slightly less than 1C.
StPRacer is offline
Old 08-20-2009, 01:13 PM
Super Moderator
racer1812's Avatar
Trader Rating: 31 (100%+)
mah cut-off what's that going to do for you with a lipo? Or do you mean that's how you set the charge rate, 5200mah and it automaticaly charges at 1C (5.2amps)
racer1812 is offline
Old 08-20-2009, 02:07 PM
Trader Rating: 17 (100%+)
I think the default on mine was 5000mah. So you would have to bump it up to keep it from shutting off early.
burnineyes is offline
Old 08-21-2009, 03:52 AM
Trader Rating: 21 (100%+)
It will charge the lipo you're asking about. The 1C charge rate for that lipo is 5200/1000 = 5.2amps. The charger is limited to 5.0amps, but that just means it will take just a little longer to charge, something you'll prob not even notice.
The charger has a compatible balance connection for teh SMC lipos as well, you will be able to plug it in, set it up, connect both connections and balance chargethe lipo you mentioned.
Duster_360 is offline
Old 08-21-2009, 10:38 AM
Super Moderator
racer1812's Avatar
I don't think you can put 5000mah back into a 5200mah lipo. Even at 6v. I would think the battery would still have more than 200mah left in it. Unless that charge can read total capacity and didn't like it being over 5000???
