-   -   Confused (https://www.rctech.net/forum/radio-electronics/320607-confused.html)
Garet Jax 08-17-2009 07:37 PM
Confused
Hello all,
I am really confused and a little scared. I decided to start learning about lipos and have come to a bit of a crossroads. I purchased a used Thunder Power 1010C that came with its TP-210V.
I also decided to buy a modified OFNA truggy starter than was being powered by a Common Sense 14.8V - 3850 mAh lipo.
I am having trouble figuring out how to charge it using the 1010C and the 210V.
Do I need this attachment? or something else?
Also any tips on using the 1010C?
Garet Jax 08-18-2009 10:02 AM
Nobody can help.
JayL 08-18-2009 10:17 AM
are you saying your battery has a balance plug that doesn't fit the included charger board?
You don't have to balance every charge, so don't worry.
or are you wondering about the settings, like this battery needs to be set at 4s charged at 3.8amps?
I have the thunderpower 610c and it is very similar....
