New Futaba CDR-5000 Super Charger >
Old 03-02-2007, 06:55 AM
  #286
If it's not going to charge LiPos someone can buy mine for $300....
Isaac is offline
Old 03-02-2007, 12:00 PM
  #287
wothrottle's Avatar
Default it can!
just charged a lipo with my cdr 5000.voltage cut-off 8,4v 8amp charging.
the charger reduced the charging amps to constant voltage charging and is lipo compatible.feeld free to try it with a nimh or nicd if you donīt believe.
wothrottle is offline
Old 03-03-2007, 01:10 AM
  #288
Trader Rating: 82 (100%+)
what version is your cdr?
marvi is offline
Old 03-03-2007, 05:54 AM
  #289
wothrottle's Avatar
V 2.3
works perfectly till 1A cv
Old 04-04-2007, 07:37 PM
  #290
Tower says the cdr-5000 is discontinued, wonder when the EVO2 is comming (did I miss the evo1???). anyway they should not even bother releasing it without lipo charging feature...
cvt01 is offline
Old 07-04-2007, 06:02 AM
  #291
A X O's Avatar
Trader Rating: 51 (100%+)
can anyone help me with the support site re: CDR 5000. My fans does not work, i want to have it fixed but i dont know where to send it.
A X O is offline
Old 07-05-2007, 11:22 AM
  #292
P2
P2's Avatar
Trader Rating: 15 (100%+)
I have never needed Futaba service but you can try this link:
http://www.futaba-rc.com/service.html
Good luck!
P2 is offline
Old 09-09-2007, 05:24 AM
  #293
Hi all,
i have a problem with my cdr 5000, i can tx charge/dx discharge but i can`t dx charge, i see a voltage as soon as the cells are connected. but after about 4 secs the charge function stops.
Can anyone give me some help/ advice.
Lee
LEE UK is offline
Old 10-11-2007, 02:32 PM
  #294
Giorgio's Avatar
Wothrottle
I'm having a CDR5000 V2.3. I'm completely virgin on Lipo, but at mu club they allow to use.
Can you explain me how set up the charger to use with lipo?
Giorgio
Giorgio is offline
Old 01-09-2012, 02:26 PM
  #295
Default Futaba CDR 5000
Anyone use this for lipo yet
racerTC3 is offline
Old 01-09-2012, 07:23 PM
  #296
Trader Rating: 21 (100%+)
I use a lipo capable chargers.....from what I read, you can only do the CC part of the lipo charge with this charger and if you don't terminate correctly at this point, you can damage the lipo.
Its not made to do lipo.
Duster_360 is offline
Old 01-14-2012, 09:10 AM
  #297
It does do lipo, just not lipo specific charger. I can change all the parameters like max volt etc. it does cc till 8.4v then the amps slowly taper off. Iam testing an orion 3600 25c lipo. The first stage 8.4v max 3.6 amps, after max voltage is reached the charger shuts off and the pack settles to 8.25v. Second stage 8.410v max 2.0 amps when done the pack settles to 8.35v. third step 8.411v max 1 amp, when done pack settles to 8.39v not 100% charge but close enuff. The orion was discharged to 6.2v before charge and it took 32XX mah and aroud 1 hour to charge so i figure it charged around 95-98%. close enuf for me and the track i race at, I will get some track time on sunday to see how the lipo does In y brushed TC3.I will also see if a fellow racer can put it on his lipo charger after mine and see how close it is to full charge. If anyone cares i will update.
racerTC3 is offline
