-   -   Lipo Help! (https://www.rctech.net/forum/radio-electronics/317017-lipo-help.html)
Elies12 08-03-2009 11:49 AM
Lipo Help!
I talked to different people and i get different answers. how to store lipos? should i leave them stored fully charged? 50%? 30%? please help any advise would be great. dont wanna mess these batteries up. there not cheap as you all know. thanks
racer1812 08-03-2009 01:29 PM
I try to stay between 50-70%.
Sorry for jacking your thread but anybody know if I'm hurting my lipos leaving them full for a week??
Wile E Coyote 08-03-2009 11:25 PM
Im no expert on this... but base on the characteristic of a lipo... don't make it below 3.0v. So if you store it, it will have a small drain of power... so as long as they don't go below 3.0v it should be okay.
As such, I'd rather store them with 100% or max power in it.
BTW I used to have a lipo that I have forsaken for more than two months... voltage droped to 2.4v if not 2.6v (in one of its cells)... at first I had problem recharging it back to life... so I simply slow charged that cell (0.2Amp max setting) with my B6 set on Auto. When it reached a little more than 3 volts, I stopped the single cell charging and rewired it to be balanced charge (it was 2s1p with 7.4v) normally.
Now that battery is in tiptop condition.
SirKarnage 08-04-2009 02:05 AM
The minimal voltage drop is the key really.
Most will say 70% due to the gradual drop.
I store either fully charged or 70. I "try" to store more at 70 so I get a good fresh charge when its time to run again.. But most times I end up charging to full, planning to run within a day or two... not expecting the rain to hold up for a week straight :(
Duster_360 08-04-2009 02:00 PM
I've been using 65-75% for storing. Have been told that routinely charging lipo to 100% and then not using it causes damage. I don't think anybody knows the time frame though - leave them a few days, several, a week or two?
When I get finished running, I charge them to 65 - 70% and then recharge before using. I left come stored at 50% for almost 3 months and they all puffed. I don't use 50% any more.
vannon 08-04-2009 06:51 PM
Good to know! :nod:
Also on the maxamps lipo care page, it says to cycle it atleast once a month since leaving them on the shelf for a prolonged period of time can cause the packs to get severely out of balance or even go dead.
ae rat 08-04-2009 07:29 PM
ive stored one for 5 months fully charged and it worked fine when i finally used it.
drperry 08-05-2009 01:26 PM
Charging them to 100% doesn't hurt them... But storing at 100% has a faster voltage drop than storing at 65 - 70%
