mamba max wont arm properly :(
hey guys,
i got a mamba max esc and a 6900kv motor. i am trying to set them to run with my spektrum dx3.0 but its not arming properly, im not getting any lights on the esc its self, no throttle but i have steering. i then put the mamba in my offorader with its crystal radio, again no love UNLESS i plug the mamba into the steering channel, but then the controler is backwards. i used to have another dx3.0 that the mamba worked fine with, but it died from a fatal 1 story drop. i tryed it with a mates dx3s and it works, but not mine :( anyone have any idea's as to how i can fix this expensive paper weight? |
mke sure that you have calibrated the esc correctly. Also with the castle esc they will not arm if any throttle is shown so make sure that all of your trims and subtrims are set to neutral.
Arming
I've had this happen on mine and if you adjust the throttle trim it will probably arm.
