Airtronics 92724 Handle 7.4V?
I'm wondering if anyone knows if the Airtronics 92724 2.4ghz receiver can handle 7.4v of power.
I keep having switch failures and I'm wondering if I can plug directly into the receiver...
Thanks!
Thanks!
Just run External BEC (Battery Eliminator Circuit)Best one would be castle Creations 10Amp Bec(small Unit) But if yo have smapce on your chassis go for the Castle Bec Pro (top Of A Line) Both Can Be Altered(Voltage,Amps and other settings Via Castle Link Which you can pick up here on rc tech for about $10 I belive Bec Pro Comes with a Card For Free Castle Link Hope It Helps
Here are specs to your Receiver I own 4 Of them Never had an issue
Specifications: * Frequency: 2.4GHz DSS
* Input Voltage (Nominal): 4.8v - 7.4v (4 and 5 cell Ni-MH and Ni-Cd packs to 2-cell Li-PO)
* Weight: .3oz (8.5g)
* Dimensions: 1.43 x .94 x .59 in (36.5 x 24 x15 mm)
* Fail Safe Limit: 3.8v Default - 3.5v to 5.0v adjustable
2 years late
