-   -   wireless are they any good? (https://www.rctech.net/forum/radio-electronics/308656-wireless-they-any-good.html)
shinta 06-30-2009 07:19 PM
im looking into going wireless on my drift car. so i dont haft to cut the ext hole in the body. does any one know if there worth it?
DezSlash 06-30-2009 07:39 PM
Wire less like 2.4ghz?? if so most are only 3-4 inches long.
HomeDawwg 06-30-2009 10:09 PM
Id say he means 2.4, perhaps getting a little confused between wireless internet 2.4 or something.
Anyway, it will still have a wire, albeit a short one.
I run mine along the top chassis plate (so it doesnt stick out the body) and works fine
shinta 07-03-2009 05:42 PM
yea that's the ones im talking about im running in doors so the rang is not really an issue you know. i just wonted your alls take on it.
one more question does a the servo matter like i got a ext one and i pluged it in to see if it worked and it out not respond, i had power but is just went to one side and stayed there.
NEVADAGARY 07-03-2009 10:30 PM
Make sure your servo is plugged into the #1 port. Try it one way and if it doesn't work reverse it. Does it turn to one side with the transmitter off or on?
shinta 07-04-2009 07:48 AM
it turns to one side when its on
