hyperion charger question
Hi guys, I have a couple of question about charging these batteries
http://b-p-p.com/product.php?product...&cat=61&page=1 I already have a 2 chargers but they both have align connectors, and I really didnt want to spend an arm and a leg on a new charger, I was looking at this http://b-p-p.com/product.php?product...&cat=24&page=1 but didnt know if I needed anything else to make it work or does it work with my venom charger or should I just go with this http://b-p-p.com/product.php?product...&cat=24&page=1 I am open to suggestions even if you guys think I should try another battery combo let me know (3 cell lipo) and as always thanks in advance |
links dont work...
Originally Posted by meon99
(Post 6005790)
links dont work...
LBA10 is good, but if u r using this with your venom charger, u cannot read individual cell V. the 403 is good, but only charge up to 3AMP, and it's the lipo only charger, get the 606i DC version, its the best value charger.
(Post 6006025)
Doesn't the Venom charger have a built-in balancer? In which case, you should just have to get a balance plug adapter.
Originally Posted by K_B
(Post 6006103)
Does the Hyperion chargers use a different style balance plug (the plug that goes into the charger itself) than the Venom charger? If not, then there's a whole bunch of balance battery plug adapters at the bottom of this page:
http://www.b-p-p.com/home.php?cat=27 |
(Post 6006187)
Venom uses JST-XH and the Hyperion lipo uses PolyQuest/Hyperion type balance connector. I had a similar prob with my Accucel-6 - it has the plug in balance connection built-in to the side of the charger like Venom does. This solved my prob - you may be able to find it somewhere over here that sells iMAX chargers and accessories -
http://www.hobbycity.com/hobbycity/s...idProduct=7350 The wire harness will plug into the side of the charger and let you connect the adapter board which will accept the PQ/HP type balance connection. The label on mine says "HP/PQ Adapter p/n SK-HQA0P100". No need to get another charger, unless you just want another of course - I only have 5, lol. |
| All times are GMT -7. It is currently 01:10 AM. |
