-   -   Charging at less then 1C? (https://www.rctech.net/forum/radio-electronics/307321-charging-less-then-1c.html)
ErikRC10 06-25-2009 02:27 PM
I just bought a Reedy 5000mah 35C lipo and a Equinox balancer. My question is can I charge at less then 1C, because the balancer only allows up to a 3amp charge rate. I know you're not suppose to trickle charge the batteries but I was wondering if it would be okay to charge at say 2.5amps.
I know you don't really need to balance the packs right away but it would make me feel better if I did.
Thanks,
Erik
whitrzac 06-25-2009 02:30 PM
Thanks,
Erik
its fine, it will just take longer:nod:
ErikRC10 06-25-2009 02:38 PM
Okay good. I just wanted to make sure I wasn't gonna destroy $140. :)
Duster_360 06-25-2009 06:02 PM
You can buy the high current adapter that lets you charge at up to 6amps with the Equinox if you want to -
http://www3.towerhobbies.com/cgi-bin...?&I=LXNGC6&P=V
Alfalfameister 06-25-2009 06:05 PM
On that note, is it actually better for the battery to charge at lower than 1C? It used to be good to charge at C/10 (1/10th) for 12-14 hours... but that was for NiMH/NiCd.
(I remember that it was better for battery longevity, and to "balance" or "equalize" the cells, but it lacked "punch"... something not that important when purely bashing).
ErikRC10 06-25-2009 07:58 PM
Yeah I saw on the instructions you could buy an adapter to charge at a higher rate but I don't like that is has to charge through those little wires.
I'm also curious about what Alfa said? Is it better to charge at a lower rate? I mean my pack can charge at 2C but I don't ever plan on charging it at that high of a rate.
whitrzac 06-25-2009 08:33 PM
it won't help the batt any by charging it at a lower rate...
