Dual Rate Steering Question?
Hey,
I just got a Spektrum DX2.0. When i first used it my steering end point were 100% but that didnt seem to turn fully so maxed left and right out at 125%. I then noticed the dual rate thumb switch, which was at 70%...... So does that mean of the 125% travel i have set, im only 70% to each side of that? Does that explain why at first the tires didnt seem to turn enough in either direction? I guess i should reset the endpoints to 100% and put the dual rate at 100% also. Tom |
You are absolutely correct. It's only going 70% of the maximum. So max out your D/R and then set your endpoints; just like you said.
| All times are GMT -7. It is currently 01:23 AM. |
