-   -   NI-CD work with lipo? (https://www.rctech.net/forum/radio-electronics/303933-ni-cd-work-lipo.html)
B.A. Racer 06-11-2009 09:35 AM
will NI-CD servos work with lipos? i have one and wanting to run it with my rc8e
Digit09 06-11-2009 09:51 AM
in a word. yes. doesnt hurt the servo at all.
JeromeK99 06-11-2009 12:29 PM
If you are running a nitro car and want to power your radio gear with a LiPo, be careful! A 2-cell 7.4v Lipo could burn up your receiver and servo if it is not made for it! You might need a voltage regulator to bring the volts down to the common 6v most radio equipment requires.
If you are running a 1/10th scale electric and your ESC can handle the voltage of your LiPo, the internal BEC will be fine. When it comes to 1/8th scale electric as in your case, it really depends on the brand of ESC you are running and if it uses a separate battery to power the electronics or if it runs through the ESC itself. If it requires a separate pack, and you want to run LiPo, you may need a voltage regulator as well.
Jerome :tire::tire:
