-   -   ezrun 9t problem (https://www.rctech.net/forum/radio-electronics/299971-ezrun-9t-problem.html)
585dodge44 05-26-2009 09:09 AM
ezrun 9t problem
I have an ezrun 9t set-up. The problem is I can't set up the throttle correctly. I just touch the throttle and the car is spinning out. It's like a light switch off or on. I can't roll into it. I tried about everything I can think of. I also tried programming the radio to the esc. Anyone else with the same problem?
585dodge44 05-29-2009 09:15 AM
no ideas?
Shimmy 05-29-2009 11:20 AM
Have you checked your radio itself? what is reverse like?
585dodge44 05-29-2009 06:41 PM
reverse is tough to get sometimes. I have tried another controller and the same thing happens. I had tried to reprogram the throttle control with controller and lose reverse or it will run backward. It is very frustrating. I tried contacting hobbywing without any reply. I figure it is probably something stupid.
Shimmy 05-29-2009 09:29 PM
If it's all been programed and setup properly, I can't think of anything sorry.
I remember reading a while ago that emailing hobbywing direct, they will only reply when it is written in chineese. Not sure if there was any truth to this though.
The other options (if no-one posts up a solution) could be to ring them or go through the people you bought it from.
585dodge44 05-30-2009 07:31 AM
well thanks anyway
chinkw1 05-31-2009 05:41 AM
ezrun esc settings
If i set the esc forward/reverse with brake or forward with brake, apart from the extra reverse function in forward/reverse with brake, is the maximum motor speed faster when set with forward with brake ?
chinkw1 05-31-2009 06:06 AM
ezrun esc settings
585dodge44 05-31-2009 08:43 AM
they seem the same to me, but I'm just a basher
